How do I know when a tool has been executed?
1063
01-08-2019 09:46 AM
MaximilianGlas
I use a tool from ArcGIS Pro to convert data from Excel by drag and drop on the map pane.
I used this example as template, but instead of executing this part automatically ...
            var result = await Geoprocessing.ExecuteToolAsync("MakeXYEventLayer_management", new string[] {
                xlsTableName,
                "POINT_X",
                "POINT_Y",
                xlsLayerName,
                "WGS_1984"
}, environments);‍‍‍‍‍‍‍
I want to call the tool in the GP pane, which lets the user the possibility to change settings:
           var paramValues = Geoprocessing.MakeValueArray(xlsTableName, string.Empty, string.Empty, layerName);
           var path = Path.Combine(@"C:\Program Files\ArcGIS\Pro\Resources\ArcToolBox\Toolboxes\Data Management Tools.tbx", "MakeXYEventLayer");
           Geoprocessing.OpenToolDialog(path, paramValues);‍‍‍‍‍‍‍‍‍‍‍‍
This works fine, but of course the user has now to execute the tool manually and after that, I want to call the ApplySymbology Tool (as in the sample code shown):
            await Geoprocessing.ExecuteToolAsync("ApplySymbologyFromLayer_management", new string[] {
              xlsLayerName,
              @"C:\Data\SDK\Default2DPointSymbols.lyrx"
But how do I get the event when the user has executed the MakeXYEventLayer Tool?
Kind regards,
Max
Robert_LeClair
Esri Esteemed Contributor
I wonder if creating a Script tool for ArcGIS Pro would be a possible avenue to explore?
