How do I get all of the tableNames from the FGDB in ArcGIS Pro SDK
2554
8
03-10-2022 02:05 AM
by Anonymous User
Not applicable
I'm working on an add-in that supports both .sde and fgdb DB connections. Although I can retrieve all of the table names when I connect to the .sde database, I'm not sure how I can do the same when I connect to the FGDB.
The code below shows how I connect to the .sde DB and retrieve tableNames from it.
Could someone please help me in retrieving all of the table names when I connect to FGDB?
Thanks in advance!!
GKmieliauskas
In both cases sde and gdb you should use the same way to get table names. Only database opening differs.
            // For sde
            DatabaseConnectionFile connector = new DatabaseConnectionFile(new Uri(sdePath));
            // For gdb
            FileGeodatabaseConnectionPath connector  = new FileGeodatabaseConnectionPath(new Uri(gdbPath));
            // coomon part
            using (Geodatabase gdb = new Geodatabase(connector))
                var defs = gdb.GetDefinitions<TableDefinition>();
                foreach (var d in defs)
                    string dsName = d.GetName();
                    // your code here
                    d.Dispose();
GKmieliauskas
            // For sde
            // For gdb
            // coomon part
                    // your code here
                    d.Dispose();
by Anonymous User
Not applicable
@GKmieliauskas I don't know why but the above code is not working as expected..'defs' is coming as 0 (count = 0)
Is anything else I need to add??
GKmieliauskas
Is code not working with sde or gdb or both?
by Anonymous User
Not applicable
Is this the same way we can fetch the columnNames also?
GKmieliauskas
Do you mean table fields?
by Anonymous User
Not applicable
Yes the fields name.
GKmieliauskas
From Table of FeatureClass definition you can get Fields:
var fields = d.GetFields();
foreach (var x in fields)
    string fieldName = x.Name;
Place after line 12 in code above
by Anonymous User
Not applicable
@GKmieliauskasworked perfectly for me Actually, I was missing a minor detail  QuesuedTask.
I can see the count  now.
Thanks a lot! 🙂
