I would like to select features (image footprints) in the view extent on a FeatureLayer. Then, I will use those selected features to call aerial images. Users do not have anything to do with the FeatureLayer. I would like making selection part behind the scenes.
Or, is there another way to show all images when user at 1:20,000 scale or bigger.
Is there a possible way to do one if these in AGP SDK?
select directly from the underlying datasource.
Thanks for your answer! Is there way to select features directly without converting a shapefile/Feature Class into a project item? Would you mind sharing a simple example selecting directly from a shapefile or feature class?
try these two examples. They should get u started.....but there are many more examples on this page:
Great resources! I use multiple layers some of them pointing to shapefiles some of them pointing to feature classes. I will see what I can do. Thanks for your answer.
