How can I select a layer and open its Layer Property window programetically in ArcGIS Pro SDK?
2010
11-20-2017 09:53 PM
SuryakantUpadhayay
Tags (1)
NarelleChedzey
Try this,
// change this to get the appropriate layer you want
var layer = MapView.Active.Map.GetLayersAsFlattenedList().FirstOrDefault();
// select it in the TOC
List<Layer> layersToSelect = new List<Layer>();
layersToSelect.Add(layer);
MapView.Active.SelectLayers(layersToSelect);
// now execute the layer properties command
var wrapper = FrameworkApplication.GetPlugInWrapper("esri_mapping_selectedLayerPropertiesButton");
var command = wrapper as ICommand;
if (command == null)
   return;
// execute the command
if (command.CanExecute(null))
   command.Execute(null);
SuryakantUpadhayay
Thanks for the solution. Its working. I was using same approach to select layer on map.
After selection I tried PropertySheet.ShowDialog method. Thus I was able to open layer properties dialog but page binding was not happening.
I tried passing DAML id of layer property sheet then null for default page and Layer which is selected as a object parameter.
Any Idea if I want to use that approach what parameters to pass for page binding? I know that PropertySheet is mainly used for customization but I was wondering if I can pass some parameter for layer page binding to make that working.
SuryakantUpadhayay
The reason behind why I want to use property sheet is that I want to programatically open Layer properties window and programetically close that too after its opened. I am actually measuring time to open and close the layer property window.
