Hide/Remove PrintLayout button in ArcGIS Pro
1776
12-14-2023 12:25 AM
imrankhadri
Is there a way to remove the Print Layout Button(esri_sharing_PrintLayout) from sharing tab from ArcGIS Pro.
I have managed removing the Export Layout using the below in the config.daml of my Addin.
<modules>
  <updateModule refID="esri_layouts">
    <splitButtons>
      <deleteSplitButton refID="esri_layouts_exportLayoutSplitButton"/>
    </splitButtons>
  </updateModule>
</modules>
I have failed to remove the print layout using the above method.
I have noticed that none of the  DAML definitions(https://github.com/Esri/arcgis-pro-sdk/tree/master/DAML) contain esri_sharing_PrintLayout.
Am I missing something here.
imrankhadri
The following did the trick.
<modules>
          <splitButtons>
              <deleteSplitButton refID="esri_layouts_exportLayoutSplitButton"/> <!-- removes the export layout button-->
          </splitButtons>
      </updateModule>
      <updateModule refID="esri_sharing">
          <groups>
              <deleteGroup refID="esri_sharing_PrintLayout" /> <!-- remove print layout button -->
          </groups>
      </updateModule>
</modules>
Thanks to everyone.
GKmieliauskas
Update module refID must be "esri_sharing".
imrankhadri
<modules>
          <splitButtons>
          </splitButtons>
      </updateModule>
          <groups>
          </groups>
      </updateModule>
</modules>
Thanks to everyone.
