Has anyone used reclassify in a C# program
1334
08-26-2019 10:53 AM
SamRideout1
I am trying to automate a process and need to perform a reclassify using visual studio and C#.  Looking for anyone who has done this successfully and possibly some source code to perform the operation.
Tags (1)
GKmieliauskas
Hi Sam,
I use raster reclassify from geoprocessing. Below is part of code:
// out_raster = arcpy.sa.Reclassify("density1000", "VALUE", "2000 1;100000 2", "DATA");
var parameters = Geoprocessing.MakeValueArray(sDlRaster, "VALUE", sReclassString, sOutRaster);
var environments = Geoprocessing.MakeEnvironmentArray(workspace: sWorkspace);
var gpResult = Geoprocessing.ExecuteToolAsync("Reclassify_sa", parameters, environments,
CancelableProgressor.None, GPExecuteToolFlags.AddToHistory);
gpResult.Wait();
You can execute every geoprocessing function you need. Get from executed command report python script ant then using python script syntax arrange your parameters in c# code. First commented line in my code is python script line.  I do it in that way because all information about geoprocessing functions and samples are in python.
SamRideout1
Thank you Gintautas.....  I greatly appreciate your answer.  I have tried it out and it works great.
