Getting table from MakeQueryTable Geoprocessing result
4024
12
09-02-2023 09:56 AM
AndreasMarth
I am creating a table using the following code.
public async Task MakeQueryTable() {
    var created = await QueuedTask.Run(() => {
        bool tableCreated = false;
        string featureClassPath = @"c:\temp\test.gdb\in_featureclass";
        string tablePath = @"c:\temp\test.gdb\in_datatable";
        var valueArray = Geoprocessing.MakeValueArray(featureClassPath + ";" + tablePath, "queryTable", "USE_KEY_FIELDS", null,
            "in_featureclass.OBJECTID #; in_featureclass.ID #; in_featureclass.NAME #; in_datatable.ID #; in_datatable.NAME",
            "in_featureclass.ID = in_datatable.ID And in_featureclass.NAME = in_datatable.NAME");
        // Execute the task and DO NOT add the table to the current map!
        Task<IGPResult> gp_result = Geoprocessing.ExecuteToolAsync("management.MakeQueryTable", valueArray, flags: GPExecuteToolFlags.None);
        IGPResult makeTableResult = gp_result.Result;
        // makeTableResult now contains the name "queryTable"
        // Trying to open the table via
        string newTablePath = @"c:\temp\test.gdb\" + makeTableResult.ReturnValue;
        // Opening this table leads to an error not able to open this table, because it dous not exist in Filegeodatabase
        // If you use GPExecuteToolFlags.AddOutputsToMap in ExecuteToolAsync then you can reference the table in the map
        var newStandaloneTable = MapView.Active.Map.GetStandaloneTablesAsFlattenedList().Where((l) => l.Name == "queryTable").FirstOrDefault() as StandaloneTable;
        return tableCreated;
I used the option GPExecuteToolFlags.None, because the result is just a temporary table.
After executing the code, I found no way to get the table object from the GP-Result.
There is a workaround. When you add the table to the active map, the you can find the table there.
Is there a way to get the table object without adding the result to the active map?
AndreasMarth
thank you for your answer, but FeatureClassToFeatureClass creates a new Dataset and therefore the full path ist returned and you can open the newly created FeatureClass with the path returned by GPResult. MakeQueryTable works different and returns only a table Name and I have found no way so far to reference this table without adding the result table to the active map and then search for the table in the map.
KenBuja
MVP Esteemed Contributor
Instead of using the geoprocessor to make the query table, can you use a query definition to make the query table from the geodatabase using the OpenQueryTable method?
AndreasMarth
Hi KenBuja,
this is not the solution for my original question, but using the OpenQueryTable method is a perfect workaround for me.  Thank you so much for your help and have a good day.
