Getting raster layer path in ArcGIS Pro using C#
1917
11-30-2021 12:42 AM
osmansheikh
I am creating an ArcGIS Pro Extension. I need to know the layer's path. To get the layer path, code developed so far:
var pointLayer = MapView.Active.Map.Layers.OfType<FeatureLayer>().FirstOrDefault();
var rasterLayer = MapView.Active.Map.Layers.OfType<RasterLayer>().FirstOrDefault();
var pointLayerPath = await QueuedTask.Run(() => pointLayer.GetPath());
var rasterLayerPath = await QueuedTask.Run(() => rasterLayer.GetPath());
pointLayerPath is assigned the correct path but rasterLayerPath is assigned a null value.
The result is the same for this code also.
MapView.Active.Map.GetLayersAsFlattenedList().OfType<RasterLayer>().FirstOrDefault();
How can I get the RasterLayer path?
GKmieliauskas
I use the following code to get raster layer path:
            return QueuedTask.Run<string>(() =>
                try
                    string fullSpec = string.Empty;
                    CIMDataConnection dataConnection = pLayer.GetDataConnection();
                    if (dataConnection is CIMStandardDataConnection)
                        CIMStandardDataConnection dataSConnection = dataConnection as CIMStandardDataConnection;
                        string sConnection = dataSConnection.WorkspaceConnectionString;
                        var wFactory = dataSConnection.WorkspaceFactory;
                        if (wFactory == WorkspaceFactory.Raster)
                            string sWorkspaceName = sConnection.Split('=')[1];
                            string sTable = dataSConnection.Dataset;
                            fullSpec = Path.Combine(sWorkspaceName, sTable);
                    return fullSpec;
                catch (Exception ex)
                    System.Diagnostics.Debug.WriteLine(ex.ToString(), System.Reflection.Assembly.GetExecutingAssembly().FullName);
                    return string.Empty;
It works for file based rasters and Esri GRIDs. I don't check how it works with sde stored rasters
GKmieliauskas
                try
                    return fullSpec;
