GetTable().GetDefinition().GetObjectIDField() giving null value
2140
02-13-2024 02:49 AM
SreenivasaRaoPigili
Hi Team,
    We are using GetTable().GetDefinition().GetObjectIDField() method to get the ObjectID fieldname and which is working well on Featureclasses having ST_Geometry field. But for the feature class having SDO_Geometry as shape field, this function is returning empty value.
FYI: I am using ArcGIS Pro SDK v2.9.
Can you please help me to understand -
1. is it correct behaviour?
2. In case if we need to use SDO_Geometry as shape, do we need to take any additional care?
3. What is the table internally this method relies on?
4. Any other related details while working with SDO_Geometry.
Thank you in advance.
SreenivasaRaoPigili
Hi @Wolf and @UmaHarano - can you please help me here.
Apologies for tagging you both directly. since this is something product level inside logic, I thought you both will help me quickly. Thanks in advance.
Aashis
by Esri Contributor
Hi, @SreenivasaRaoPigili; I am wondering if your "feature class having SDO_Geometry" is registered.
SreenivasaRaoPigili
Hi @Aashis - Yes it is.
SreenivasaRaoPigili
Hi , Anyone has any thoughts on this. Please share. Thank you.
Aashis
by Esri Contributor
If possible, could you please post the sample data to help us reproduce the issue? Thank you.
