GetDefinitions takes forever to list feature classes in geodatabase
907
07-22-2024 08:30 AM
AndyFoy
I'm trying to list a subset of feature classes in a SQL Server database. So I'm executing geodatabase.GetDefinitions<FeatureClassDefinition>() and then filtering the resulting IReadOnlyList based on a wildcard match.
Most SQL tables and views are fine when executing geodatabase.GetDefinitions<FeatureClassDefinition>(), but the problem is that it is handing whenever it encounters any complex SQL views. I can see this using the Diagnostic Window when it displays, e.g.
function="Geodatabase.Table.OpenDataset" code="BeginOpenDataset"
but then never reaches an equivalent "EndOpenDataset".
My code is:
            await QueuedTask.Run(() =>
                try
                    // Try and get all of the feature class definitions.
                    IReadOnlyList<FeatureClassDefinition> fcDefinitions = _geodatabase.GetDefinitions<FeatureClassDefinition>();
                    foreach (var definition in fcDefinitions)
                        // Get the name of the feature class and add it to the list.
                        _tableNames.Add(definition.GetName());
                catch (Exception)
                    // GetDefinitions throws an exception.
                    throw;
I'm only trying to list all of the feature classes so that I can filter them to a subset that the user can then choose from and run a query on. How can I resolve this so that it doesn't hang?
Aashis
by Esri Contributor
@AndyFoy What does your complex SQL view look like? Could you please give us some details so we can reproduce the issue in-house and fix it?
