Get all features at given point
1007
03-11-2025 02:34 AM
sonj
At the given point it should return 3 red lines and 1 blue line. But it is returning the green line too. Why does this green line return without intersecting? (Pro SDK 3.4)
SelectionSet selectionSet = MapView.Active.GetFeaturesEx(mapPoint.Extent,true,true);
neil_perol
Hi @sonj,
Is there a reason for using mapPoint.Extent instead of just mapPoint? Also it seems you've got the whollyWithin parameter set to 'true'. I'd try using just mapPoint and setting whollyWithin to the default 'false'.
sonj
Hi Neil,
Nothing specific, I have not used mapPoint.Extent it returns all three green lines. If I change to default 'false' the result remains the same.
