Geoprocessing Async Error
1677
04-12-2023 06:13 PM
tzz_12
I am trying to run a few geoprocessing methods in the sequence they occur. It works fine if I just keep it simple, but I want to add some additional parameters, such as environment and GPExecuteToolFlags. There is an errors that states the "Object reference is not set to an instance of an object."  Please see my code below.
var in_features = new List<FeatureLayer>() { FC_Layer1, Layer2 };
var args = Geoprocessing.MakeValueArray(in_features, intersectFC);
GPExecuteToolFlags outputOnMapNone = GPExecuteToolFlags.None;
GPRun("analysis.Intersect", args,null,null,outputOnMapNone);
var Agg_para = Geoprocessing.MakeValueArray(intersectFC, intersectSortFC, GPRun("management.Sort", Agg_para, null,null,outputOnMapNone);
var in_features2 = new List<FeatureLayer>() { FCLayer, Layer2 };
var args2 = Geoprocessing.MakeValueArray(in_features2, layer);
GPExecuteToolFlags flag = GPExecuteToolFlags.GPThread;
GPRun("analysis.Intersect", args2,null,null,flag);
public async void GPRun(string GPTool, IReadOnlyList<string> parameters, IEnumerable<KeyValuePair<string, string>> env,CancelableProgressor prog,GPExecuteToolFlags flag)
   var gp_result = await Geoprocessing.ExecuteToolAsync(GPTool, parameters, env, prog, flag);
   Geoprocessing.ShowMessageBox(gp_result.Messages, "Geoprocessing Error
      Messages",gp_result.IsFailed ? GPMessageBoxStyle.Error :
      GPMessageBoxStyle.Default);
Thanks for your help!
GKmieliauskas
I think problem with line:
You use Agg_para parameter without initialization in running management.Sort tool
Wolf
by Esri Regular Contributor
Your code snippet has a problem, this line doesn't make much sense when GPRun returns void, plus a closing ')' is missing:
i would suggest setting a breakpoint before you call Geoprocessing.ExecuteToolAsync and inspect the content of the parameters array to make sure the content looks correct.  If you run the same GP tool manually you can look at the corresponding python command to get the proper parameter sequence for the input parameters array.
tzz_12
Hi Wolf,
When I copy and paste the code into the post, I had to fix the formatting of the code, and  I accidently deleted some parts of the code by accident. Here is the code for the sort geoprocessing method below. The error, "NullReferenceException: Object reference is not set to an instance of an object.", occurred in the GPRun method, when it calls the Geoprocessing.ExecuteToolAsync.
var Agg_para = Geoprocessing.MakeValueArray(intersectFC, intersectSortFC, AggregateField);
utility.GPRun("management.Sort", Agg_para);
Wolf
Sorry about the delay.  I noticed a problem with the variation of "Geoprocessing.ExecuteToolAsync" that you are using.  It turns out that the 'progressor' parameter cannot be null.
You can create a Progressor using this snippet:
CancelableProgressorSource cps = new CancelableProgressorSource("Run GP", "Canceled");
var progressor = cps.Progressor;
This variation of your code worked for me:
protected async override void OnClick()
  try
    var intersectInputLyr1 = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(fl => fl.Name.Equals("TestPolygons")).FirstOrDefault();
    var intersectInputLyr2 = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(fl => fl.Name.Equals("TestLines")).FirstOrDefault();
    var intersectOutputFC = System.IO.Path.Combine(Project.Current.DefaultGeodatabasePath, "IntersectFc");
    var intersectOutputSortFC = System.IO.Path.Combine(Project.Current.DefaultGeodatabasePath, "IntersectSortFc");
    var AggregateField = "Description";
    var in_features = new List<FeatureLayer>() { intersectInputLyr1, intersectInputLyr2 };
    var argsSortedIntersect = Geoprocessing.MakeValueArray(in_features,
      intersectOutputFC,
      "ALL",//join_attributes = "ALL",
      null,//cluster_tolerance = None,
      "INPUT"//output_type = "INPUT"
    GPExecuteToolFlags noMapOutput = GPExecuteToolFlags.None;
    // set overwrite flag
    var env = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
    await GPRun("analysis.Intersect", argsSortedIntersect, env, cps.Progressor, noMapOutput);
    var Agg_para = Geoprocessing.MakeValueArray(intersectOutputFC, intersectOutputSortFC, AggregateField);
    await GPRun("management.Sort", Agg_para, env, cps.Progressor);
    var intersectInputLyr3 = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(fl => fl.Name.Equals("TestPoints")).FirstOrDefault();
    var intersectOutputFc2 = System.IO.Path.Combine(Project.Current.DefaultGeodatabasePath, "IntersectPointFc");
    var in_features2 = new List<FeatureLayer>() { intersectInputLyr3, intersectInputLyr2 };
    var argsIntersect2 = Geoprocessing.MakeValueArray(in_features2, intersectOutputFc2);
    await GPRun("analysis.Intersect", argsIntersect2, env, cps.Progressor, flag);
  catch (Exception ex)
    MessageBox.Show($@"Exception: {ex.ToString()}");
public async Task GPRun(string GPTool,
  IEnumerable<KeyValuePair<string, string>> env = null,
  CancelableProgressor prog = null,
  GPExecuteToolFlags flag = GPExecuteToolFlags.Default)
  try
    if (gp_result != null) Geoprocessing.ShowMessageBox(gp_result.Messages, "Geoprocessing Result",
  catch
    var gp_result = await Geoprocessing.OpenToolDialogAsync(GPTool, parameters, env);
