Geodatabase Edits - Features deleted from attribute table but visible on map
2900
03-23-2021 11:53 PM
PrashantKirpan
I'm trying to delete features from filegeodatabase feature class. After executing edit operation, features get deleted from attribute table but  still appearing on Map.
I'm referring following code snippet : https://github.com/esri/arcgis-pro-sdk/wiki/ProSnippets-Geodatabase#deleting-a-rowfeature
Here is my sample code:
 await QueuedTask.Run(() =>
                using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(Project.Current.DefaultGeodatabasePath))))
                using (FeatureClass enterpriseTable = geodatabase.OpenDataset<FeatureClass>("PointFeature"))
                    EditOperation editOperationForPoints = new EditOperation();
                    editOperationForPoints.Callback(context =>
                            QueryFilter deleteFilter = new QueryFilter { WhereClause = $"OBJECTID NOT IN (27)" };
                            using (RowCursor rowCursor = enterpriseTable.Search(deleteFilter, false))
                                while (rowCursor.MoveNext())
                                    using (Feature row = (Feature)rowCursor.Current)
                                        context.Invalidate(row);
                                        row.Delete();
                        }, enterpriseTable);
                    try
                        deletionResult = editOperationForPoints.Execute();
                        if (!deletionResult) message = editOperationForPoints.ErrorMessage;//"Edit operation failed."
                    catch (GeodatabaseException exObj)
                        message = exObj.Message;
.Execute() returning true value but ErrorMessage says "Edit operation failed."
Any help would be appreciated.
Prashant
PrashantKirpan
Thanks for the reply. Called await Project.Current.SaveEditsAsync(); after success of edit operation and working fine. Working in both callback and without callback
-Prashant
GKmieliauskas
Have you tried deleting without callback?
Just:
                                        editOperationForPoints.Delete(row);
More info here:
https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/#topic9512.html
EditOperation ErrorMessage you can set which you want. If it is not set, you see default message.
editOperationForPoints.ErrorMessage = "My error message";
PrashantKirpan
-Prashant
by Anonymous User
Not applicable
With the callback you can also try invalidating the row both before (as you have) and after the delete call.
PrashantKirpan
Hi SeanJones,
Yes, I tried that too. Even I tried to set null geometry, store feature and then delete but if I don't call save edits then issue persists.
-Prashant
