Flow direction from Utility Network Edge Feature
484
05-18-2026 06:08 AM
EdwardBlair
In the Geometric Network using ArcObjects you can dig in to the details of a network edge and determine its flow direction -- which is useful in a number of circumstances, including if you want to determine the source side and load side of a given electric device (in a radial network).   I can't seem to find an equivalent way to do this with the UN and the Pro SDK, but I could be missing something.
Any guidance here would be much appreciated.
Thx,
Ed
sjones_esriau
Hi Ed,
In the absence of IUtilityNetwork2.GetFlowDirection(edgeEID)... I think the recomended way now is to run a trace and iterpret the results.
Robert posted a sample a few months ago where you could derive the flow direction from the trace JSON.
Version 7/8 of the UN also has some interesting methods to work with and manipulate the digitized direction but I haent looked into that yet.
EdwardBlair
Sorry I missed this post the other day.   Thank you for the reply!
Unfortunately, as you probably know, having to do the trace to derive the flow direction has a bunch of drawbacks.
Thanks again,
Ed
