Finding the Lat/Long of the centerpoint of current map view.
1276
6
05-22-2025 03:47 PM
RogerAsbury
I'm trying to convert some old VB code into C#, and unsure of how to proceed with code that does that task mentioned in the subject. Below is the old vb code. My problem being that I do not know the modern .net sdk equivalents for the calls in C#. It seems like it should be pretty simple to get the view extent and calculate the center, but apparently, it's a bit more involved then I expected. 🙂
Try 'TRY TO GET THE CENTER SCREEN LOCATION FROM THE ACTIVE VIEW, JUST SHOW THE FORM ON ERROR
            Dim pPoint As ESRI.ArcGIS.Geometry.IPoint
            pPoint = New ESRI.ArcGIS.Geometry.Point
            pPoint.X = (m_pArcMapAV.Extent.XMax - m_pArcMapAV.Extent.XMin) / 2 + m_pArcMapAV.Extent.XMin
            pPoint.Y = (m_pArcMapAV.Extent.YMax - m_pArcMapAV.Extent.YMin) / 2 + m_pArcMapAV.Extent.YMin
            Dim pGeoCoordSystem As ESRI.ArcGIS.Geometry.ISpatialReference
            Dim pProjCoordSystem As ESRI.ArcGIS.Geometry.ISpatialReference
            Dim pGeoTrans As ESRI.ArcGIS.Geometry.IGeoTransformation
            Dim pSpatRefFact As ESRI.ArcGIS.Geometry.ISpatialReferenceFactory
            pSpatRefFact = New ESRI.ArcGIS.Geometry.SpatialReferenceEnvironment
            pGeoCoordSystem = pSpatRefFact.CreateGeographicCoordinateSystem(ESRI.ArcGIS.Geometry.esriSRGeoCSType.esriSRGeoCS_WGS1984)
            pProjCoordSystem = pSpatRefFact.CreateProjectedCoordinateSystem(ESRI.ArcGIS.Geometry.esriSRProjCSType.esriSRProjCS_NAD1983SPCS_AK3FT)
            pGeoTrans = pSpatRefFact.CreateGeoTransformation(ESRI.ArcGIS.Geometry.esriSRGeoTransformationType.esriSRGeoTransformation_NAD1983_To_WGS1984_2)
            Dim pGeo As ESRI.ArcGIS.Geometry.IGeometry2
            pGeo = pPoint
            pGeo.SpatialReference = pProjCoordSystem
            pGeo.ProjectEx(pGeoCoordSystem, ESRI.ArcGIS.Geometry.esriTransformDirection.esriTransformForward, pGeoTrans, 0, 0, 0)
            Me.tbxLat.Text = CStr(pPoint.Y)
            Me.tbxLon.Text = CStr(pPoint.X)
        Catch ex As Exception
            'DO NOTHING
        End Try
Also, lol at the code paste feature not having a vb option.
Roger Asbury
Analyst/Programmer - Fairbanks North Star Borough
GKmieliauskas
I understood that you need the code in VB. The same classes and methods you can call from c#.
8-17 lines in VB code makes projection with transformation. wkid 102633 is code for ArcObjects esriSRProjCS_NAD1983SPCS_AK3FT.
    var areaOfInterest = MapView.Active.Extent;
    MapPoint pPoint = MapPointBuilderEx.CreateMapPoint((areaOfInterest.XMax - areaOfInterest.XMin) / (double)2 + areaOfInterest.XMin, (areaOfInterest.YMax - areaOfInterest.YMin) / (double)2 + areaOfInterest.YMin, MapView.Active.Map.SpatialReference);
    SpatialReference pGeoCoordSystem = SpatialReferenceBuilder.CreateSpatialReference(SpatialReferences.WGS84);
    SpatialReference pProjCoordSystem = SpatialReferenceBuilder.CreateSpatialReference(102633);
    ProjectionTransformation pGeoTrans = ProjectionTransformation.Create(pProjCoordSystem, pGeoCoordSystem);
    MapPoint pProjectedPoint = GeometryEngine.Instance.ProjectEx(pPoint, pGeoTrans) as MapPoint;
    Console.WriteLine(pProjectedPoint.Y);
    Console.WriteLine(pProjectedPoint.X);
Documentation link is here
GKmieliauskas
There is one sample project for VB in Esri Community ArcGIS Pro Samples. Solution is here. Try code below for your functionality:
            Dim areaOfInterest = MapView.Active.Extent
            Dim pPoint As MapPoint
            pPoint = MapPointBuilderEx.CreateMapPoint((areaOfInterest.XMax - areaOfInterest.XMin) / 2 + areaOfInterest.XMin,
                (areaOfInterest.YMax - areaOfInterest.YMin) / 2 + areaOfInterest.YMin, MapView.Active.Map.SpatialReference)
            Dim pGeoCoordSystem As SpatialReference
            Dim pProjCoordSystem As SpatialReference
            Dim pGeoTrans As ProjectionTransformation
            Dim pProjectedPoint As MapPoint
            pProjectedPoint = CType(GeometryEngine.Instance.ProjectEx(pPoint, pGeoTrans), MapPoint)
            Console.WriteLine(CStr(pProjectedPoint.Y))
            Console.WriteLine(CStr(pProjectedPoint.X))
            'DO NOTHING
        End Try
As I understand your map spatial reference is esriSRProjCS_NAD1983SPCS_AK3FT. So, instead of creating pProjCoordSystem you can use Map spatial reference
RogerAsbury
Here is what I have so far, in C#:
await QueuedTask.Run(() =>
    var extent = MapView.Active.Extent;
    MapPoint mapPoint = MapPointBuilder.CreateMapPoint(
        (extent.XMax - extent.XMin) / 2 + extent.XMin,
        (extent.YMax - extent.YMin) / 2 + extent.YMin,
    MessageBox.Show($"Latitude: {mapPoint.Y}\nLongitude: {mapPoint.X}", "Coordinates", MessageBoxButton.OK, MessageBoxImage.Information);
For a specific location in Fairbanks, Alaska, this gives me:
However, I would expect something more along the lines of
Latitude: 64.8614161192099
Longitude: -147.90539636224
My guess is that in your vb code, lines 8-17 perform that conversion, but I'm uncertain how to do that in C#. The library names/classes appear to be different? My lack of knowledge on the various spatial reference types is probably not helping.
Roger Asbury
GKmieliauskas
JonathanDewalt
This would get you the lat / long of your extent.
var extent = rmg.Common.Methods.GetMapViewExtentAsGeometry(this, mapView, null);
// Convert to WGS84
var wgs84 = new SpatialReferenceBuilder(4326).ToSpatialReference();
var projectedCentre = GeometryEngine.Instance.Project(extent, wgs84);
// Get the center of the extent
var center = GeometryEngine.Instance.Centroid(projectedCentre);
dbllat = center?.Y.ToString();
dbllong = center?.X.ToString();
JonathanDewalt
This would get you the lat / long of your extent in c#
// Convert to WGS84
RogerAsbury
Thank you both. I tried both solutions and they both work. Love seeing more than one way to arrive at a solution. 🙂 Wish I could mark both as the solution.
Guess I was getting hung up in the conversion.
Roger Asbury
