FGDB and working with it.
2454
6
05-10-2022 04:46 AM
DavidMrázek
is there any way to select all FC and datasets from FileGDB? I would like to extract all elements from the path to .gdb and add them to the list. Is it possible?
Thank you
David
Aashis
by Esri Contributor
You can call GetDefinitions for individual dataset types:
var fcDefinitions = geodatabase.GetDefinitions<FeatureClassDefinition>();
var tableDefinitions = geodatabase.GetDefinitions<TableDefinition>();
var datasetDefinitions = geodatabase.GetDefinitions<FeatureDatasetDefinition>();
// Similar for other dataset types
// Loop through the results
foreach (var definition in datasetDefinitions)
  Console.WriteLine(definition.GetName() + "=>" + definition.DatasetType);
  definition.Dispose();
Aashis
by Esri Contributor
DavidMrázek
Thank you very much that's it 🙂
DavidMrázek
Just a question, I'm trying to make Layers out of it, but I don't know how to put it together to select FeatureClass and FeatureDataset.
 var seznamFeateruLayer = new List<FeatureLayer>();
                    Geodatabase geodatabase =
                        new Geodatabase(
                            new FileGeodatabaseConnectionPath(
                                new Uri(_cesta))); //C:\Users\mrazekd\Documents\ArcGIS\Projects\test\test.gdb
                    var fcDefinice = geodatabase.GetDefinitions<FeatureClassDefinition>();
                    var datasetDefinice = geodatabase.GetDefinitions<FeatureDatasetDefinition>();
                    if (datasetDefinice.Count != 0)
                        foreach (var definition in datasetDefinice)
                            var jmenoFcDataset = definition.GetName();
                            var url = _cesta + @"\" + jmenoFcDataset;
                            Uri uri = new Uri(url);
                            await QueuedTask.Run(() => LayerFactory.Instance.CreateLayer(uri, mapView.Map));
                            if (fcDefinice.Count != 0)
                                foreach (var definice in fcDefinice)
                                    var jmenoFc = definice.GetName();
                                    if ()//I don't know how to separate the two here
                                        var urlFc = _cesta + @"\" + jmenoFc;
                                        Uri uriFc = new Uri(urlFc);
                                        await QueuedTask.Run(() => LayerFactory.Instance.CreateLayer(uriFc, mapView.Map));
                                    FeatureLayer featureLayerJmeno =
                                        mapView.Map.FindLayers(jmenoFc).First() as FeatureLayer;
                                    seznamFeateruLayer.Add(featureLayerJmeno);
Aashis
by Esri Contributor
This snippet shows you the path differences in feature datasets and feature classes.
You can get the path using featureClass.GetPath().
var fcName = featureClassDef.GetName();
using (var fc = geodatabase.OpenDataset<FeatureClass>(fcName))
  FeatureDataset featureDataset = fc.GetFeatureDataset();
  if(featureDataset !=null)
   // do something with feature class inside feature dataset
  var path = fc.GetPath();
  LayerFactory.Instance.CreateLayer(path, MapView.Active.Map);
To filter the feature classes only inside the feature dataset you can use geodatabase.GetRelatedDefinitions() method.
foreach (var featureDatasetDef in featureDatasetDefinitions)
 IReadOnlyList<Definition> datasetsInFeatureDataset = geodatabase.GetRelatedDefinitions(featureDatasetDef, DefinitionRelationshipType.DatasetInFeatureDataset);
 foreach(Definition datsetInFeatureDataset in datasetsInFeatureDataset)
  if(datsetInFeatureDataset.DatasetType == DatasetType.FeatureClass)
	using (FeatureClassDefinition featureClassDefinition = datsetInFeatureDataset as FeatureClassDefinition)
	  var fcName = featureClassDefinition.GetName();
		LayerFactory.Instance.CreateLayer(path, MapView.Active.Map, layerName:$"From Dataset{fcName}");
DavidMrázek
Thank you very much !!!
