Error when using ExportToWKB on multipart geometry
1033
03-24-2025 05:45 AM
RadekMandovec
When I try use ExportToWKB:
var wkbGeom = GeometryEngine.Instance.ExportToWKB(WkbExportFlags.WkbExportPolygon, geometry);
 I get following error:
System.Exception: 'COMException: An unspecified error has occurred.'
There is mentioned "Does not support curves" in the documentation, but nothing about multiparts. So is it supposed to work on multiparts or not? I tried to create very simple multipart polygon with two squares and it does not work on it either.
JoshuaBixby
MVP Esteemed Contributor
Have you tried WkbExportMultiPolygon flag?
JoshuaBixby
RadekMandovec
Of course I didn't:-) Now everything works fine! Thank you very much!
