Entity Framework support
1131
02-08-2024 01:41 AM
TomiRönkkö
What kind of support is there for using Entity Framework in Esri Geodatabase, we have Postgre Enterprise Geodatabase in use at the moment and we have a plan in creating a CRUD application that would use this database. We have used EF in the past extensively in other app development, but not with Esri products.
Thanks for you help,
Br,
Tomi
TimSexton1
Entity Framework would likely by-pass the geodatabase versioning and agnostic approach that Esri has in place when using their APIs to access the data for CRUD operations.
