Edit Operation failing when trying to Modify rows in a feature class
3454
12-12-2018 11:12 AM
KylePerri
I am trying to loop through every row in a feature class and edit one of it's fields, but for some reason it always fails.
Here is my code:
QueuedTask.Run(async () =>
foreach(var featureClass in featureClasses)
                            var editOperation = new EditOperation()
                                Name = "Revert IsEdited Field",
                                EditOperationType = EditOperationType.Short,
                                ShowProgressor = false
                            var editedRowsQuery = new QueryFilter()
                                WhereClause = $"{IS_EDITED_FIELD} = 1"
                            try
                                using (var rowCursor = featureClass.Search(editedRowsQuery))
                                    int isEditedFieldIndex = rowCursor.FindField(IS_EDITED_FIELD);
                                    while (rowCursor.MoveNext())
                                        using (var row = rowCursor.Current)
                                            editOperation.Modify(row, isEditedFieldIndex, 0);
                            catch (System.ArgumentException)
                                continue;
                            catch (GeodatabaseException)
                                continue;
                            bool succeeded = await editOperation.ExecuteAsync();
                            featureClass.Dispose();
Is there something I'm doing wrong?
I've tried using editOperation.Execute as well, but same error.
by Anonymous User
Not applicable
Kyle,
You're explicitly setting the edit operation type to short, the operation will fail if the featureclass is "long" or registered as versioned. Normally there's no need to explicitly this, the operation works it out based on the edits.
Also check the editoperation.errormessage property after the failure to see if there's any known error being reported.
RichRuh
Hi Kyle,
The first thing I would try is to change the call to FeatureClass.Search as follows:
using (var rowCursor = featureClass.Search(editedRowsQuery, false))
This creates a non-recycling cursor, which is what you want for editing.
Recycling cursors are described in more detail in the conceptual doc.
I hope this helps,
--Rich
KylePerri
Hey Rich,
Thanks for the reply. Unfortunately, this didn't fix it for me.
- Kyle
by Anonymous User
Not applicable
Kyle,
KylePerri
Hey Sean,
Thanks for the reply. This was in fact the issue. Once I removed the operation type it worked.
