DropInfo.TargetModel is null in 2.3
1865
05-17-2019 04:14 PM
MaxMax2
In 2.3 something went wrong. TargetModel is null in DropInfo that passed to OnDrop method of a drop handler. It makes it impossible to determine where I drop my object. I should perform drop on MapView only. In 2.2 TargetModel contained that MapView when I dragging an object over it.
Is it a bug or there is API to specify where it is valid to drop an object?
Tags (1)
UmaHarano
Hi Max
If you drop into a pane in Pro that holds a MapView, it will be an IMapPane.  From this, you can get the MapView.
This works even if you drop into a Pane that is not the active one (gray on the tab name).
Thanks
Uma
UmaHarano
Hi Max,
There was an issue with the sequence of how custom drop handlers were being evaluated in Pro 2.2 on drag drop and that was fixed in 2.3. Because custom handlers are now evaluated first, the TargetModel property cannot always be guaranteed to be populated. Instead, please use this code snippet below: We will be updating the relevant samples for 2.4.
public override void OnDrop(DropInfo dropInfo)
            #region Implement Your OnDrop Here
            if (FrameworkApplication.Panes.ActivePane is IMapPane)
                //a drag is being made on the active map
                var view = ((IMapPane)FrameworkApplication.Panes.ActivePane).MapView;
                // globe or local
                if (view.ViewingMode == MapViewingMode.SceneGlobal ||
                  view.ViewingMode == MapViewingMode.SceneLocal)
                    //we are in 3D
                    OnDrop3D(dropInfo);
                else
                    //we are in 2D
                    OnDrop2D(dropInfo);
            #endregion
            dropInfo.Handled = true;
Thanks
Uma
MaxMax2
Hi Uma,
FrameworkApplication.Panes.ActivePane is the same thing as drop target? I think no. At now I use VisualTarget to determine where I'm dropping my object:
        private static bool IsOverMapView(DropInfo dropInfo)
            if (dropInfo == null)
                return false;
            if (dropInfo.TargetModel is MapView)
                return true;
            var visualTarget = dropInfo.VisualTarget;
            if (visualTarget == null)
                return false;
            // TODO: seems there is a bug in ArcGIS Pro SDK 2.3 with TargetModel is null, so this is a workaround
            return visualTarget.GetType().Name == "MapPaneView";
UmaHarano
Hi Max
Thanks
Uma
