download image
4031
04-20-2016 08:10 AM
AndreaLópez
I am new in all about Arcgis. Can you tell me how I can donwload the map?
I have a map with marker I need to take a photo and save in my CRM because I am using this image in my reports!
I am working with google and i used static map for this
UmaHarano
Hi Andre
There are a couple ways by which you can accomplish what you need:
1. Make a new Layout in your project. Add a Map frame to your layout. Define the map you want within that map frame.  You can then use the following code snippet (also available in the API Reference guide here​) to export the map as a PNG file:
//This example demonstrates how to export an individual map frame on a layout to PNG.
//Added references
using ArcGIS.Desktop.Core;  //Project
using ArcGIS.Desktop.Layouts;  //Layout classes
using ArcGIS.Desktop.Framework.Threading.Tasks;  //QueuedTask
using ArcGIS.Desktop.Mapping;  //Export formats
public class ExportMapFrameToPNGExample
   public static Task ExportMapFrameToPNGAsync(string LayoutName, string MFName, string Path)
   //Reference a layoutitem in a project by name
  LayoutProjectItem layoutItem = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault(item => item.Name.Equals(LayoutName));
   if (layoutItem == null)
   return Task.FromResult<Layout>(null);
   //Create PNG format with appropriate settings
  PNGFormat PNG = new PNGFormat();
  PNG.Resolution = 300;
  PNG.OutputFileName = Path;
   return QueuedTask.Run(() =>
        //Export MapFrame
       Layout lyt = layoutItem.GetLayout(); //Loads and returns the layout associated with a LayoutItem
       MapFrame mf = lyt.FindElement(MFName) as MapFrame;
        if (PNG.ValidateOutputFilePath())
            mf.Export(PNG);
2. If you want your add-in to display Pro's "Export Map" dialog, you can use the following code snippet to execute an ICommand using IPlugInWrapper. This snippet can be added to a button's click handler, for example:
internal class Button1 : Button
       protected override void OnClick()
           IPlugInWrapper wrapper = FrameworkApplication.GetPlugInWrapper("esri_sharing_ExportMap"); // Export Map button's ID.
           var command = wrapper as ICommand; // tool and command(Button) supports this
           if ((command != null) && command.CanExecute(null))
               command.Execute(null);
Thanks
Uma Harano
ArcGIS Desktop SDK team
