Does ArcGIS Pro SDK support TIN API
2602
6
11-13-2019 02:55 AM
sai_phaneendra
I am looking for Arcobjects SDK alternatives for ITin and ITinEdit in ArcGIS Pro SDK. Does ArcGIS Pro SDK support this?
Appreciate any help on references to samples or API methods.
Tags (1)
ClaytonCrawford
There is no equivalent for ITinEdit in Pro at this time. There are several geoprocessing tools for creating and editing TINs though. If these don't suffice can you describe why?
AdamDavis
Hi Clayton,
Given that you only say that there is no Tin Editing does that mean there is TIN access - if so where is it?
At 2.4 there is FileSystemDatastoreType only for Raster and Shapefile
Adam
ClaytonCrawford
There isn't a low level API exposed for TIN in Pro. However, GP tools for creating, modifying, and analyzing TINs do exist and can be called from scripts/code.
AdamDavis
Hi Clayton,
Thanks for the clarification.
Is it on Esri's API road map and if so, near, medium or long term?
Adam
sai_phaneendra
I have used GP tools for create tin and edit tin. Now, I am looking for an alternative to QueryPixelBlock from TIN in Pro, I couldn't find any sdk methods or tools.
ClaytonCrawford
How about the TIN To Raster geoprocessing tool?
