Do I understand the threading concept right?
3307
02-10-2020 07:54 AM
BarbaraSchneider2
As far as I understand, multithreading in the Pro SDK is used to separate the user interface thread from the worker thread, i.e. a user can still perform tasks in the GUI while the worker thread does its work.
Can I also split up time consuming tasks into multiple threads? In my application, I create some feature classes, and I assign renderers to the corresponding layers. I split this up into multiple threads as follows:
Task task = QueuedTask.Run(() => CreateFootprintFCAsync(fdPath, "Footprint", spatialRef));
task = QueuedTask.Run(() => CreatePerimeterFCAsync(fdPath, "Perimeter", spatialRef));
task = QueuedTask.Run(() => CreateHabitatFCAsync(fdPath, "Habitat", spatialRef));
However, this code doesn't run asynchronously, but sequentially. Am I doing something wrong or is this expected behaviour?
RichRuh
Queued Task sets up code so that it runs on the Main CIM Thread.  This is a special thread used to access the geodatabase.  So the behavior you are seeing is correct.
--Rich
RichRuh
--Rich
BarbaraSchneider2
Thanks, Rich.
Is my assumption above correct?: multithreading in the Pro SDK is used to separate the user interface thread from the worker thread, i.e. a user can still perform tasks in the GUI while the worker thread does its work.
RichRuh
Yes, this is correct.
More information about multithreading in the Pro SDK is available here: ProConcepts Framework · Esri/arcgis-pro-sdk Wiki · GitHub
