Disable the ProWindow Minimize and Maximize buttons
1681
04-18-2019 11:37 AM
BrianBulla
Honored Contributor
I cannot figure out how to disable the Minimize and Maximize buttons on a ProWindow.  I see the choices for Appearance - Window Style, but even setting it at ToolWindow the Min/Max buttons are still there:
<controls:ProWindow x:Class="RowChanged_TEST.ProWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:controls="clr-namespace:ArcGIS.Desktop.Framework.Controls;assembly=ArcGIS.Desktop.Framework"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        xmlns:extensions="clr-namespace:ArcGIS.Desktop.Extensions;assembly=ArcGIS.Desktop.Extensions"
        mc:Ignorable="d"
        Title="Tracked Layers" Height="470.347" Width="300"
        WindowStartupLocation="CenterOwner" ResizeMode="CanResizeWithGrip" WindowStyle="ToolWindow"
    <controls:ProWindow.Resources>
        <ResourceDictionary>
            <ResourceDictionary.MergedDictionaries>
                <extensions:DesignOnlyResourceDictionary Source="pack://application:,,,/ArcGIS.Desktop.Framework;component\Themes\Default.xaml"/>
            </ResourceDictionary.MergedDictionaries>
        </ResourceDictionary>
    </controls:ProWindow.Resources>
    <Grid>
        <ListBox x:Name="lstLayers" Margin="10,37,10,10" BorderBrush="{DynamicResource Esri_TextControlBrush}" FontSize="14"/>
        <Label x:Name="label" Content="Map Frame - Layer Name" Foreground="{DynamicResource Esri_TextControlBrush}" HorizontalAlignment="Left" Height="35" Margin="10,2,0,0" VerticalAlignment="Top" Width="195" FontSize="15"/>
    </Grid>
</controls:ProWindow>
Any ideas on what might be going on??
UmaHarano
You can set this in the XAML for the ProWindow -
 ShowMinButton="False"
 ShowCloseButton="False" ShowMaxRestoreButton="False"
<controls:ProWindow x:Class="ProWindow.ProWindow1"
        mc:Ignorable="d"
        Title="ProWindow1" Height="300" Width="300"
UmaHarano
        mc:Ignorable="d"
BrianBulla
Honored Contributor
Thanks Uma!!
