Different button behaviour in ribbon tab and menu
1927
05-04-2021 06:48 AM
GKmieliauskas
I have placed the same button to ribbon tab and menu for burger button.
If I change caption of button in different workflows, button in ribbon reacts to changes, but button in menu reacts only to enable/disable.
Is is possible to get the same button behaviour in menu?
UmaHarano
Hi
Can you please give me a little info on how you changed the caption in your workflows? Also, please let me know the Pro version you are using.
I tried a simple caption change in the ribbon button and it worked for me. The same button placed in the burger menu reflected the change.
Thanks
Uma
GKmieliauskas
Hi.
My ArcGIS Pro version 2.7.3
I have tried different ways:
1. Override OnUpdate
protected override void OnUpdate()
if (_isLogged)
Caption = "Sign out";
else
Caption = "Sign in";
2. On custom event
private void onAuth(AuthorizationDataMessage msg)
if (msg != null && !string.IsNullOrEmpty(msg.AccessToken))
_isLogged = true;
else
_isLogged = false;
3. Setting Plugin properties
var plugin = FrameworkApplication.GetPlugInWrapper("my_autorization_Btn");
plugin.Caption = "Sign out";
I have tried with Esri button "esri_editing_SaveEditsBtn" too. Behaviour was the same
UmaHarano
Thank you for this information. I am now able to see the problem too. I will submit an issue for this bug and get back to you when I have updates on its resolution.
Thank you for reporting this one!
Uma
TimSexton1
@UmaHarano  We are still seeing this issue on 3.x.  Is there any update on this?  We were able to work around the issue using a DynamicMenu.
