CreateRenderer Failing
2266
12
11-18-2025 09:48 AM
MichaelTodd
Under what circumstances would a layer CanCreateRenderer method return true, yet running CreateRenderer with the same renderer caused the following error:
ArcGIS.Desktop.Mapping.MappingException: 'Error HRESULT E_FAIL has been returned from a call to a COM component.'
Can't nail down why the error. Everything seems to be set up correctly, using a FeatureLayer, all required elements are set in the classes. To top it off, this code has been working since at least ArcGIS Pro 2.8 and has just recently started to crash Pro. Any ideas?
MichaelTodd
Attached is a file geodatabase with the two files in question. I assume the code will work with them since they were exported to a file geodb. I have a feeling that the layers themselves, currently living in our Enterprise geodb (Sql Server) are corrupted (usable, but corrupted). If the attached layers work, I would hazard that as being the case.
If so, I suppose the next step is: how do I fix those layers in the Sql Server without breaking things?
MichaelTodd
Because, of course I forgot the attachment.
GKmieliauskas
Your code works with file gdb you attached.
Check your map content for broken layers. If they exist, remove them and try your code
