Create relationship class between two tables Pro sdk
2318
07-01-2021 11:30 AM
MarvisKisakye1
Is there a way to create a relationship class between two TABLES with the pro sdk? Here is the code that I have used but the relationship class is not created in the geodatabase like I expect. @CharlesMacleod  @Wolf @UmaHarano
var originFc = gdb.OpenDataset<FeatureClass>(mmember.Name);
                    var destFc = gdb.OpenDataset<FeatureClass>(etTableName);
                    var oidname = originFc.GetDefinition().GetObjectIDField();
                    var origPrimaryKey = originFc.GetDefinition().GetFields().First(f => string.Equals(oidname, f.Name));
                    var destForeignKey = destFc.GetDefinition().GetFields().First(f => string.Equals(ETTableSchema.rowIDFieldName, f.Name));
                    var rlDesc = new VirtualRelationshipClassDescription(origPrimaryKey, destForeignKey,
                        RelationshipCardinality.OneToMany);
                    rlDesc.ForwardPathLabel = "HasEdits";
                    rlDesc.BackwardPathLabel = "AllObjects";
                    rlDesc.Name = $"{mmember.Name}_HTE";
                    var rlClass = originFc.RelateTo(destFc, rlDesc);
RichRuh
We started to add some data definition language (DDL) capabilities in the Pro SDK at 2.8, but you cannot yet create relationship classes (it's planned for a future release).  For now, you have to use the geoprocessing API and use the Create Relationship Class tool.
--Rich
RichRuh
--Rich
Wolf
by Esri Regular Contributor
@MarvisKisakye1 You probably already looked at this sample:  arcgis-pro-sdk-community-samples/Geodatabase/DynamicJoins at master · Esri/arcgis-pro-sdk-community-...
However, the sample only creates a 'dynamic' result (added to the TOC).  To create a relationship class in the geodatabase you have to follow Rich's suggestion.
