Create QueryLayer without the use of ArcGIS.Core.Data
1677
09-15-2021 12:39 AM
TomGeo
Currently I am creating QueryLayer using ArcGIS.Core.Data functionality where I retrieve data from an Oracle database, utilizing the Database, and DatabaseConnectionProperties class etc.
It works! However, it is relatively slow, and I think it has something to do with the way the SDK connects and reads the database in question.
For simple retrieving of unique values from a database table I am not using Esri classes any more, but went with Oracle.ManagedDataAccess. It is a drastic change in response time doing so, and my "customers" love it.
Hence, I would like to use Oracle.ManagedDataAccess to query the database, retrieve the data and use them to create a FeatureClass, and FeatureLayer.
Retrieving the data is not the problem, but creating the FeatureClass is.
Currently I am creating the FeatureClass through the OpenTable method of the ArcGIS.Core.Data Database class. That means I am back to square one, because I have to establish the connection through the AGP SDK.
Is there a way to use Oracle.ManagedDataAccess to create QueryLayer?
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
RichRuh
Thomas-
There's no way to directly create a FeatureClass/FeatureLayer from a data structure returned from an Oracle API.
Some ideas:
  • Create a plugin datasource that reads from the Oracle.ManagedDataAccess. Plugin datasources are described here. The resulting feature class is read-only.
  • Copy the data into a memory geodatabase. This is read-write, but of course any changes you make are to the memory database, not the Oracle tables.
I hope this helps.
--Rich
RichRuh
Thomas-
Some ideas:
I hope this helps.
--Rich
TomGeo
Thanks Rich,
I will try the plugin datasource way.
