Create Interactive viewshed
807
11-24-2025 01:33 AM
ModyBuchbinder
I would like to create with code something similar to this: https://pro.arcgis.com/en/pro-app/latest/help/mapping/exploratory-analysis/interactive-viewshed.htm
Using code I can read parameters from file and control the process beter.
I found the Viewshed class that looks like the class I need.
There are no examples I could  find.
I could set the Camera properties and the Viewshed properties, but I cannot connect it to any MapView.
The MapView property is read-only. It is null when I run my code and no viewshed is created on screen.
There should be a way to define it but I cannot find it.
I connect my camera into the map (Camera camera = MapView.Active.Camera) then I just updated the properties (x,y, etc) but it did not help.
Thanks
GKmieliauskas
MapView has method AddExploratoryAnalysisAsync. Viewshed is derived from ExploratoryAnalysis. Code below:
        protected override async void OnClick()
            var mapView = MapView.Active;
            if (mapView == null)
                return;
            var observerPointLayer = mapView.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(layer => layer.Name.Equals("ObserverPoint"));
            if (observerPointLayer == null)
                return;
            ExploratoryAnalysis item0 = await QueuedTask.Run(() => {
                #region Get the observer point
                var observerPtCursor = observerPointLayer.Search();
                MapPoint observerPoint = null; MapPoint targetPoint = null;
                MapPoint observerPointProjected = null;
                while (observerPtCursor.MoveNext())
                    var observerPtFeature = observerPtCursor.Current as Feature;
                    observerPoint = observerPtFeature.GetShape() as MapPoint;
                    observerPointProjected = GeometryEngine.Instance.
                                                  Project(observerPoint, mapView.Map.SpatialReference) as MapPoint;
                #endregion
                Camera camera = new Camera(observerPointProjected.X, observerPointProjected.Y, 10.0, 0, 0);
                Viewshed viewshed = new Viewshed(camera, 0, 180, 100, 1000);
                return viewshed;
            await mapView.AddExploratoryAnalysisAsync(item0);
GKmieliauskas
                return;
                return;
                #endregion
                return viewshed;
ModyBuchbinder
Hi
It is working great - thanks.
There should be a sample or a snippet or at least a line in the help for Viewshed class or ExploratoryAnalysis class.
Thanks again
Mody
