Create FeaturLayer from Shape File without adding it to the Map
284
yesterday
EugeneStaten
Hi....
I am porting and old ArcMap add-in to ArcGIS Pro 3.6 using the SDK.
The previous code loads a FeatureLayer form a shape file without auto adding it to the Map.
Here is the Code:
 public static ILayer LoadShapeFile(string path)
     ILayer layer = null;
     try
         if (File.Exists(path))
             string directory = Path.GetDirectoryName(path);
             string name = Path.GetFileNameWithoutExtension(path);
             // Create a new ShapefileWorkspaceFactory CoClass to create a new workspace
             ESRI.ArcGIS.Geodatabase.IWorkspaceFactory workspaceFactory = new ESRI.ArcGIS.DataSourcesFile.ShapefileWorkspaceFactoryClass();
             ESRI.ArcGIS.Geodatabase.IFeatureWorkspace featureWorkspace = (ESRI.ArcGIS.Geodatabase.IFeatureWorkspace)workspaceFactory.OpenFromFile(directory, 0); // Explicit Cast
             ESRI.ArcGIS.Geodatabase.IFeatureClass featureClass = featureWorkspace.OpenFeatureClass(name);
             if (featureClass != null)
                 ESRI.ArcGIS.Carto.IGeoFeatureLayer featureLayer = new ESRI.ArcGIS.Carto.FeatureLayerClass();
                 featureLayer.FeatureClass = featureClass;
                 featureLayer.Name = featureClass.AliasName;
                 layer = featureLayer;
     catch (Exception ex)
         DebugLog.Error(ex);
         throw;
     return layer;
ArcGIS Pro 2.6 wont let me do this, it forces me to add the layer to the Map:
Here is my code:
    public FeatureLayer LoadShapeFile(string shapefileFullPath)
        if (File.Exists(shapefileFullPath))
            return null;
        FeatureLayer newLayer = QueuedTask.Run<FeatureLayer>( async () =>
            try
                string directory = Path.GetDirectoryName(shapefileFullPath)!;
                string shapeFileName = Path.GetFileName(shapefileFullPath)!;
                string featureClassName = Path.GetFileNameWithoutExtension(shapefileFullPath)!;
                // Run the geoprocessing tool to add a projection to the shape file
                IGPResult result = DefineShapeFileProjection(shapefileFullPath);
                if (result.IsFailed)
                    return null;
                var connectionPath =
                    new FileSystemConnectionPath(new Uri(directory), FileSystemDatastoreType.Shapefile);
                using (var datastore = new FileSystemDatastore(connectionPath))
                    using (FeatureClass featureClass = datastore.OpenDataset<FeatureClass>(shapeFileName))
                        FeatureLayerCreationParams layerCreationParams =
                            new FeatureLayerCreationParams(featureClass)
                                Name = featureClassName, // Set a custom name for the new layer
                        // Create the layer and (add it to the map):-|
                        return LayerFactory.Instance.CreateLayer<FeatureLayer>(layerCreationParams,
                            MapView.Active.Map);
                MessageHandling.ErrorMessage(ex);
                return null;
            return null;
        }).GetAwaiter().GetResult();
        return newLayer;
The LayerUtils.cs file allow adding a layer or many layers to the Map later.
We first do a little preprocessing before doing so.
Is there a way to create a FeatureLayer without adding it to the map.
send null inplace of the Map container will throw an exception.
