Control fields width in table Frame
1147
07-11-2021 10:31 PM
mody_buchbinder
When you create a table frame in layout with pro (not in code) you have an option to set the field width to Auto width.
Is there any option in the SDK to set this property?
Thanks
Wolf
by Esri Regular Contributor
You can use the 'FittingStrategy' property of the CIMTableFrame to set the auto sizing behavior:
var theTable = LayoutElementFactory.Instance.CreateTableFrame(layout, EnvelopeBuilder.CreateEnvelope(llTab1, urTab1), mfElm, lyr, new string[] { "Label", "Description" });
var def = theTable.GetDefinition() as CIMTableFrame;
def.FittingStrategy = TableFrameFittingStrategy.AdjustColumnsAndSize;
def.FillingStrategy = TableFrameFillingStrategy.ShowAllRows;
theTable.SetDefinition(def);
