Configuration conflict with PerfTools
2002
02-14-2017 11:36 PM
rbae
If the PerfTools Add In is installed, the Start Page of my custom configuration is skipped.  It loads the Splash Screen and goes straight into ArcGIS Pro, creating a new project by default (i.e. MyProject_).  Is there a setting that will allow PerfTools and the Start Page to co-exist?
IanSims
Ryan--Denny, our developer on this, has examined what happens when
/config:ConfigWithStartWizard
is passed on the cmd line.  It turns our PerfTools does not process this cmd, but it mistakenly thinks it needs to execute a script so PerfTools creates a project.  This causes the custom configuration to skip its start page.
As a workaround, you must uninstall PerfTools if you want to start ArcGIS Pro with a custom configuration.  We will be releasing an upcoming version that fixes this issue.
Cheers,
Ian S.
rbae
Perfect - Thank you Ian.
