ComboBox with predefine string values in dockpane
1452
09-16-2025 07:07 AM
ModyBuchbinder
I am trying to put a ComboBox in my dockpane with pre defined string values (Something like Polygon/Polyline/Point). They never change.
All the examples I found have ObservableCollection with some classes or other complex behavior that I do not need.
My ComboBox is coming out empty.
Anybody have very simple example on how to do it?
Thanks
GKmieliauskas
You can do it from xaml:
<ComboBox Height="23" Name="comboBox1" Width="120">
    <ComboBoxItem Content="Polygon"/>
    <ComboBoxItem Content="Polyline"/>
    <ComboBoxItem Content="Point"/>
</ComboBox>
ModyBuchbinder
Already done this.
It does not looks like MVVM - is that the only way?
GKmieliauskas
XAML:
            <ComboBox ItemsSource="{Binding GeometryTypes}" SelectedItem="{Binding SelectedGeometryType, Mode=TwoWay}" Text="Select Option" />
ViewModel:
        public List<string> GeometryTypes => new List<string>() { "Polygon", "Polyline", "Point" };
        public string SelectedGeometryType { get; set; } = "Polygon";
ModyBuchbinder
After playing a lot (and consult AI) this is my solution
XML
<ComboBox x:Name="types"  DisplayMemberPath="Name"  ItemsSource="{Binding TypesItems}" SelectedItem="{Binding SelectedType, Mode=TwoWay}"/>
Helper class:
public class MyItemClass
    public string Name { get; set; }
Fill the list
 private ObservableCollection<MyItemClass> _TypesItems;
// fill the list in ctor
           TypesItems = new ObservableCollection<MyItemClass>
           new MyItemClass {  Name = "Item 1" },
           new MyItemClass {  Name = "Item 2" },
           new MyItemClass {  Name = "Item 3" },
 public ObservableCollection<MyItemClass> TypesItems
     get => _TypesItems;
     set => SetProperty(ref _TypesItems, value);
and finally get the selected
       private MyItemClass _selectedType;
       public MyItemClass SelectedType
           get => _selectedType;
           set => SetProperty(ref _selectedType, value);
Wolf
by Esri Regular Contributor
