Close and open the current project
168
2 weeks ago
MichaelKohler
Stupid question here😁
I'm trying to close and open the current project to reset the project for the Add-In. Nothing happens with the code as expected because the project is already open.
I have a "reset" function where i find all the elements in the Add-in and reset them. If the project could be "reloaded", it would be easier.
protected override void OnClick()
    var curProject = Project.Current;
    string projectPath = curProject.URI;
    Project.Current.SetDirty(false);
    openPrj(projectPath);
private async void openPrj(string projectPath)
    await Project.OpenAsync(projectPath);
Thanks!
CharlesMacleod
Once a project is open, the application does not return to the "there is not a project open" state. That only occurs at start up. To "reset" a project/addin you would essentially have to open _another_ project and, from "that" project, re-open your desired one.
