Changing Ribbon Icon at Runtime
892
07-26-2024 03:14 PM
khamillejaynes20
Hello, is there any way to change an icon on the ribbon at runtime? For example, if a state or condition changes, can i also change the picture that shows up on the ribbon?
Tags (3)
GKmieliauskas
For Button or MapTool you can override OnUpdate method:
        protected override void OnUpdate()
                if (myCondition)
                    Caption = "Title1";
                    SmallImage = BuildImage("small_image1.png");
                    LargeImage = BuildImage("large_image1.png");
                else
                    Caption = "Title2";
                    SmallImage = BuildImage("small_image2.png");
                    LargeImage = BuildImage("large_image2.png");
Or set from code:
private void ChangeCaptionImage()
  IPlugInWrapper wrapper = FrameworkApplication.GetPlugInWrapper("MyAddin_MyCustomButton");
  if (wrapper != null)
    wrapper.Caption = "new caption";
    // ensure that T-Rex16 and T-Rex32 are included in your add-in under the images folder and have
    // BuildAction = Resource and Copy to OutputDirectory = Do not copy
    wrapper.SmallImage = BuildImage("T-Rex16.png");
    wrapper.LargeImage = BuildImage("T-Rex32.png");
private ImageSource BuildImage(string imageName)
  return new BitmapImage(PackUriForResource(imageName));
private Uri PackUriForResource(string resourceName)
  string asm = System.IO.Path.GetFileNameWithoutExtension(
      System.Reflection.Assembly.GetExecutingAssembly().Location);
  return new Uri(string.Format("pack://application:,,,/{0};component/Images/{1}", asm, resourceName), UriKind.Absolute);
