Change mouse cursor to a specific tool
3470
09-08-2017 06:10 AM
BrianBulla
Honored Contributor
Is there a listing available of ToolIDs within ArcPro?  I've been looking through the API Reference and have only found one reference to esri_editing_SketchLineTool, but I would imagine there must be a whole list of them somewhere.
What I want to do is automatically switch to the Select tool after a MapTool I am coding is finished running.
BrianBulla
Honored Contributor
I found it!!
FrameworkApplication.SetCurrentToolAsync("esri_mapping_selectByRectangleTool");
BrianBulla
Honored Contributor
I found it!!
UmaHarano
Glad you found it!
The IDs are listed in the Pro SDK wiki pages in this page:  ArcGIS Pro DAML ID Reference
You can also see them in Pro when you enable the control IDs to be displayed.
Control IDs
Also, there is a Pro SDK Utility that you could use to get the DAML ids directly into you Add-in solution.
ArcGIS Pro SDK for .NET utilities
