Can I select layer on contents view programmatically ?
181
a week ago
rdc_hirohara
I am currently attempting to port a tool from ArcGIS Desktop + ArcObjects to ArcGIS Pro. In ArcObjects, I was able to select a layer in the content view using the following code:
IMap map = ArcMap.Document.FocusMap;
IActiveView activeView = (IActiveView)map;
IContentsView contentsView = mxd.CurrentContentsView;
contentsView.SelectedItem = layer;
However, in ArcGIS Pro, I cannot find an equivalent functionality. Is there a corresponding feature available in ArcGIS Pro? I could not find it in the API reference.
GKmieliauskas
Yes, You can. MapView has method SelectLayers.
GKmieliauskas
rdc_hirohara
Thank you for the information, GKmieliauskas. The SelectLayers method in MapView is exactly what I was looking for. I appreciate your help!
GKmieliauskas
So, accept as solution
