call ComboBox method from MapTool
1730
08-20-2020 05:58 PM
JackKelley1
In the SDK's Examples\MapExploration\GetMapCoordinates.cs, the map coordinates become available in HandleMouseDownAsync(...).
Afterwards, still in HandleMouseDownAsync(...), I need to invoke a method defined in a ComboBox, something like:
public void SearchXY (double x, double y)
{ this.queryRows = this.database.Query(x, y); UpdateCombo(); }
How can I obtain a reference to this ComboBox?
Or is an event needed?
Tags (1)
GKmieliauskas
JackKelley1
Thanks Gintautus, That code looks promising. Will the DAML need to be changed?
I wish that the SDK did the work for me. The add-in's default Module singleton would provide access by some "FindItem" method.
GKmieliauskas
Hi Jack,
It is possible to get your combobox in ArcGIS Pro way, but there is no samples with combobox.
var comboBox = FrameworkApplication.GetPlugInWrapper("your_combox_id");
I have checked it returns wrapper with CommandType value ComboBox, but I don't what to do next. For example, cast to your combobox class or something like that. You can investigate that way.
JackKelley1
Yes Gintautas, that code in Combo Box Reload showed the way.
The add-in has classes Module1, MapTool1ComboBox1, plus my own Database.
The required call from MapTool1 works fine and is simply
Module1.Current.ComboBox1.SearchXY(x, y);
Visual Studio made some suggestions to simplify the code (and the Config.daml needed no change).
In brief, the additions / modifications were:
Module1:
public ComboBox1 ComboBox1 { get; set; } = null;
ComboBox1
public ComboBox1()
    if (Module1.Current == null) return;
    Module1.Current.ComboBox1 = this;
    this.database = new Database();
    //UpdateCombo();
