Combo Box Reload
2269
02-09-2018 09:36 AM
MKa
I am using an ESRI Combo Box in my toolbar.  This Combo Box is loaded with the IDs of whatever polygons are in my map.  When a user switches to another location, with a whole new set of polygons, I want my Combo Box to update itself.  The problem is that I can't seem to figure out how to run my Update/Populate logic from outside of the combobox code.  I need to be able to tell the combo box from other functions to revalidate or reinitialize itself?  I think I need to make some static reference to this function, but can't seem to be able to accomplish this?  The below code works initially, but when the user switches, i need to be able to call updateCombo from anywhere, or just tell the combo to reload.
        public GoToCurrent()
            UpdateCombo();
        public async void UpdateCombo()
            try
                Enabled = false;
                Clear();
                SortedSet<string> FieldIdList = await FeatureServiceManagement.getFeatureLayerUniqueList("Current Field", "", "CurrentFieldId");
                if (!FieldIdList.IsNullOrEmpty())
                    foreach (string fieldID in FieldIdList)
                        Add(new ComboBoxItem(fieldID));
                Enabled = true;
            catch (Exception e)
                logError("UpdateCombo", e);
GKmieliauskas
You can make property in your module class to set combo box. On startup you need from combo box class to set that property to combo box itself. When you need to update combo box content you will find your module and read combobox property and call "UpdateCombo" method.
    public class MyModule : Module
        private static MyModule _this = null;
        private MyComboBox _combo = null;
        internal MyModule()
            _this = this;
        /// <summary>
        /// Retrieve the singleton instance to this module here
        /// </summary>
        public static MyModule Current
            get
                return _this ?? (_this = (MyModule)FrameworkApplication.FindModule("My_Module"));
        public MyComboBox PolygonCombo
            get
                return _combo;
            set
                _combo = value;
                _combo.UpdateCombo();
public class MyComboBox : ComboBox
   /// <summary>
   /// Constructor to initialize the ComboBox
   /// </summary>
   public MyComboBox()
      MyModule modOwner = MyModule.Current;
      if (modOwner == null) return;
      modOwner.PolygonCombo = this;
Another way is to use some kind of messaging. I use that approach in my applications:
https://stackoverflow.com/questions/23798425/wpf-mvvm-communication-between-view-model
JuanManuelPazDiaz
hello
I am new to this, I have a similar problem. I have already implemented your code and it works perfectly when my application loads for the first time. What I don't understand is how I can make it update at runtime from a button on a form external to the combobox class.
Thank you
GKmieliauskas
Sorry for delay. Code for update combobox selection below:
	internal class Test_button1 : Button
		protected override void OnClick()
			Module1 modOwner = Module1.Current;
			if (modOwner.PolygonCombo != null)
				modOwner.PolygonCombo.SelectedItem = modOwner.PolygonCombo.ItemCollection.FirstOrDefault();
			else
				MessageBox.Show("Polygon Combo is null");
