Bug in extension Pane.ActivateAndDelay(this Pane pane, int delay = 100)
1067
07-16-2024 01:13 AM
Asimov
I discovered the bug on subject while working on an Addin where I needed such extension. Currently working on 3.2 SDK, the extension is located in the namespace ArcGIS.Desktop.Internal.Mapping.UtilityExtensions and is defined as follows:
public static Task ActivateAndDelay(this Pane pane, int delay = 100)
    if (pane != null)
        pane.Activate();
        if (delay > 0)
            return Task.Delay(100);
    return Task.CompletedTask;
The bug is pretty obvious: the parameter 'delay' is just ignored. Note that this bug also affects at least another extension, ActivateAndExecute(this Pane pane, Func<Task> function, int delay = 100), since it calls ActivateAndDelay().
Tags (3)
NarelleChedzey
Thanks for bring this bug to our attention.  This will be fixed for the Pro 3.4 release.
NarelleChedzey
