ArcGIS Pro SDK (VS 2015)
3933
09-10-2015 03:45 AM
JasonHorning
Is anyone else having issues getting all of the ArcGIS Pro SDK templates to load for VS 2015?  I installed both the ArcGIS Pro SDK for .NET and ArcGIS Pro SDK for .net (Utilities) through the extensions and updates process, restarting VS after each install and only see the "ArcGIS Pro Add-ins" template under New Project>Templates>Visual C#>ArcGIS.
Running Windows 7 Enterprise SP1
Visual Studio Community Edition
UmaHarano
Hi Jason
The ArcGIS Pro SDK for .NET templates includes one Project template (the one you are seeing under New Project>Templates>Visual C#>ArcGIS) and 18 Item Templates. After you create your add-in project, there are many "ArcGIS Pro UI elements" you can add to it using the "Item Templates" provided with the SDK.
Please refer to the Pro Guide: Your first add-in in the arcgis-pro-sdk repo for step by step instructions on how you can create an ArcGIS Pro add-in.
Uma Harano
ArcGIS Pro SDK team
UmaHarano
Hi Jason
Uma Harano
ArcGIS Pro SDK team
