arcgis pro sdk button with image not shown
1267
02-28-2023 07:01 AM
Janaki_Gattu
KenBuja
MVP Esteemed Contributor
Can you supply the code you've used to build the button and insert the image? Where is the image stored?
Wolf
by Esri Regular Contributor
Make sure your image has the 'Build Action' set to 'Resource':
and declare the image in the config.daml as shown (make sure to replace the <your_DLL_Name> with the name of your add-in):
 <button id="TaxParcelPlenary_DisasterFlood" caption="Flood Disaster" className="DisasterFlood" keytip="B3"
                loadOnClick="true"
                largeImage="pack://application:,,,/<your_DLL_Name>;component/Images/DisasterFlood32.png">
          <tooltip heading="Flood Disaster">
            Adjust the Tax Assessment after a declared Flood Disaster<disabledText />
          </tooltip>
 </button>
