ArcGIS Pro Icons
19597
11
02-12-2016 05:41 AM
HarmBruinsma1
I'm an ArcGIS Pro SDK Developer. Before I have developed in ArcObjects in ArcGIS Desktop.
If you install the developer kit of ArcGIS Desktop. You install also the icons which are used in ArcGIS Desktop.
For example, the icons are installed here:
C:\Program Files (x86)\ArcGIS\DeveloperKit10.0\Icons
But now i'm developing in ArcGIS Pro. Where can I find the icons which are used in ArcGIS Pro?
I need the Icons because I want to make my icons in the same style as the style of the ArcGIS Pro Icons.
UmaHarano
Hi Ted,
Here is a link on the wiki that gives you the list of the icons available with Pro.
https://github.com/Esri/arcgis-pro-sdk/wiki/DAML-ID-Reference-Icons
Thanks!
Uma
JohnDye2
Would be nice if these could be made available as SVG. I'm sure some Esri designer has those resources somewhere. Sometimes the existing icons don't fit well for a particular tool. I don't want to deviate from the Pro aesthetic though, so I'd like to be able to open up a couple of symbols in Illustrator and grab elements of one symbol and copy them into other symbols to create completely new symbols that still match the ArcGIS Pro design.
