ArcGIS Pro 3.3.4 QueuedTask.Run throws an ERROR TaskStatus.WaitingForActivation.
1624
02-26-2025 10:50 AM
RichardDaniels
MVP Regular Contributor
Has anyone encountered this issue and have a better work around?
Many of the commonly used methods in ArcGIS Pro SDK are required to be run on the 'MCT' thread. The code is wrapped in a QueuedTask.Run block and in most cases, we need to Wait for the result before continuing processing. This is often done with Task.Wait(). However, I've recently ran into a situation where Task.Wait throws an ERROR because the task has a status of TaskStatus.WaitingForActivation. Is this a known issue?
Task t1 = QueuedTask.Run(() =>
try { //do some long running work }
catch (Exception eX)   { // handle the error }
//code added to prevent error
while (t1.Status==TaskStatus.WaitingForActivation)
Thread.Sleep(500);
loopCount++;
if (loopCount > 22) // 11 seconds max wait time
     break;
if (t1.Status==TaskStatus.WaitingForActivation) { throw new exception("Task failed to Start within 11 seconds.");  }
t1.Wait();
UmaHarano
Hi
A comment pattern to await the QueudTask is to use the await key word.
Task t1 = await QueuedTask.Run(() =>
 A good resource that documents Pro's Asynchronous programming concepts is available in this wiki:
ProConcepts: Asynchronous Programming in ArcGIS-Pro
RichardDaniels
In you example if we had a line 9, that did more work (e.g., getting t2.Result), would your code Wait till the task is completed before running line 9?
RichardDaniels
But await does not actually cause the code to Wait 🙂
