OpenItemDialog not able to browse to the portal node as the initial location
499
02-27-2025 01:17 AM
RITASHKOUL
We have created our own startup page. Our page also contains a button "Start with another template". I want the same behavior of this button as the default one (present in the default Pro start page), which is that the initial location should always be the portal node and it should filter to Project Templates (aptx). But I am not able to achieve that using OpenItemDialog.
I tried to include "esri_browsePlaces_Online" in the includes property of BrowseProjectFilter (got this idea from one of the existing questions in the community https://community.esri.com/t5/arcgis-pro-sdk-questions/openitemdialog-local-only-no-portal/td-p/1311...). But still not able to make it work.
Also forced OpenItemDialog to always use initial location by setting property AlwaysUseInitialLocation as true. But still the same issue.
For me, it is always being opened at the Project node.
Can someone help me on this?
@UmaHarano @Wolf @CharlesMacleod @GKmieliauskas @NarelleChedzey
Tags (1)
GKmieliauskas
Try code below:
            BrowseProjectFilter bdf = new BrowseProjectFilter();
            bdf.Name = "Online";
            bdf.Excludes.Add(@"project_browse_place_project");
            bdf.Excludes.Add(@"esri_browsePlaces_Computer");
            OpenItemDialog itemDlg = new OpenItemDialog
                Title = "Open portal items",
                MultiSelect = false,
                BrowseFilter = bdf
            bool? ok = itemDlg.ShowDialog();
RITASHKOUL
@GKmieliauskas But I also wanted to filter only on Project Templates (APTX) files. So if any of folders in the Portal node  have project templates file, those should only be visible else no files should be visible.Itried this
var browseProjectFilter = new BrowseProjectFilter
Name = Resources.ProjectTemplatesBrowseFilterName,
FileExtension = ".APTX"
browseProjectFilter.Excludes.Add("project_browse_place_project");
browseProjectFilter.Excludes.Add("esri_browsePlaces_Computer");
browseProjectFilter.AddFilter(BrowseProjectFilter.GetFilter("esri_browseDialogFilters_project_templates"));
var openItemDialog = new OpenItemDialog
Title = "Project Templates (APTX)",
BrowseFilter = browseProjectFilter,
Filter = ItemFilters.Project_Templates
}; Added the project templates filter but not working. I can all files even if they are not APTX files
RITASHKOUL
I got this. This will be achieved using BrowseFileMode = true
