ArcGIS Pro 3.0 - System.Data.SqlClient.dll reference assembly
2243
09-08-2022 02:33 PM
MadsHoumann
The ArcGIS Pro 3.0 install include System.Data.SqlClient.dll reference assembly.
As far as I can see, the actual implementation assemblies are not installed.
Our add-in needs System.Data.SqlClient, but since the ArcGIS Pro 3.0 installed version: 'C:\Program Files\ArcGIS\Pro\bin\System.Data.SqlClient.dll' is just the reference assembly it doesn't work.
And this version is loaded even when the correct implementation assembly is included in the add-in.
Am I missing something here? or is it a bug in the ArcGIS Pro 3.0 install?
Wolf
by Esri Regular Contributor
You can look at this example (from community samples) which is using the Microsoft.Data.SqlClient NuGet in its plug-in project: ProSqlExpressReader solution more specifically the 'Microsoft.Data.SqlClient' package reference in this project: arcgis-pro-sdk-community-samples/ProSqlExpressDb.csproj at master · Esri/arcgis-pro-sdk-community-sa...
Also check here regarding SqlClient in .Net 6.0:  Introducing the new Microsoft.Data.SqlClient - .NET Blog
Wolf
MadsHoumann
I guess switching to Microsoft.Data.SqlClient will be an OK option for us.
RichardDaniels
MVP Regular Contributor
The real question is WHY is System.Data.SqlClient.dll event included in the ArcGIS Pro 3.0 install package, and why is it located at C:\Program Files\ArcGIS\Pro\bin?
ArcGIS Pro is built on .Net Framework 6.0.5 which does not support the use of System.Data.SqlClient. All Add-ins should be rebuilt to use Microsoft.Data.SqlClient and WebView 2 (vs. WebBrowser).
