ArcGIS namespaces not found
2565
11-03-2022 03:09 AM
Daniel4
Hi Everybody, I inherits a visual studio ArcGIS project from an old collega. but when I open up the project in VS, it cant not find the ArcGIS namespaces.
It showing this:
And this:
In my Extension manager I have install this:
I am using VS 2019 and the ArcGIS Project are used in AGP 2.9.
I do not have any problems creating new AGP projects in VS.
What am I missing?
Wolf
by Esri Regular Contributor
To support ArcGIS Pro 2.9 you need to install and use Visual Studio 2019.   Follow these steps to resolve the assembly path issue:
FAQ · Esri/arcgis-pro-sdk Wiki (github.com)
tempStephenRhea_NV5
Do you have Pro installed on your machine? The SDK will pull in references from the Pro installation path unless you're using the ArcGIS Pro Extensions NuGet package (https://www.nuget.org/packages/Esri.ArcGISPro.Extensions)
Daniel4
I have Pro 2.9 installed.
Wolf
Daniel4
Great 🙂 Everything looks so pretty now.
