AddOverlayControl not adding to MapView
1370
11-28-2024 06:58 AM
CarstenAndersson
I want to add a standard Slider control (System.Windows.Controls.Slider) as an overlay control in the active map view. My code is quite simple, but nothing is added to the map view and no exception is raised. Here's the code:
var sliderControl = new Slider
    Minimum = 1,
    Maximum = 10,
    Width = 400,
    Value = 1,
    Height = 40,
    Visibility = System.Windows.Visibility.Visible
var mapViewOverlayControl = new MapViewOverlayControl(sliderControl, true, false, false, OverlayControlRelativePosition.BottomCenter, .5, .8);
MapView.Active.AddOverlayControl(_mapViewOverlayControl);
Not sure what I'm doing wrong. Any help would be greatly appreciated.
Regards
Carsten
Tags (3)
GKmieliauskas
You have global variable _mapViewOverlayControl (with underscore) which is null, I think. So change it to:
MapView.Active.AddOverlayControl(mapViewOverlayControl);
Without underscore it works fine
GKmieliauskas
CarstenAndersson
Of course. How could I miss that?! Thanks a lot 🙂
