Adding items to combobox list using a dictionary
2548
6
04-03-2025 05:16 AM
mstranovsky
I have a dictionary of values named "odDict".   When i use the following code it only adds the first value in the dictionary.  How can i get it to populate the list using all values in the dictionary?
foreach (KeyValuePair<string, string> kvp in odDict)
string key = kvp.Key;
string val = kvp.Value;
cmbOverlayDistrict.Items.Add(val);
RadekMandovec
You can use:
List<object> values = odDict.Values.ToList();
cmbOverlayDistrict.Items.AddRange(items: values.ToArray());
mstranovsky
Thank you for the reply but when using your code I now see this:
RadekMandovec
And if you use this?
List<object> values= new(odDict.Values);
SumitMishra_016
I have put my sample code, it is working for me
<ComboBox Name="CaseNumberComboBox" Width="200" ItemsSource="{Binding CaseNumbers}" SelectionChanged="CaseNumberComboBox_SelectionChanged"/>
public ObservableCollection<string> CaseNumbers { get; set; } = new();
// Temporary list to avoid multiple UI updates
List<string> caseNumbersList = new();
while (await reader.ReadAsync())
    string caseNo = reader.GetString(0);
    caseNumbersList.Add(caseNo);
// Update UI on the main thread
System.Windows.Application.Current.Dispatcher.Invoke(() =>
    CaseNumbers.Clear();
    foreach (var caseNo in caseNumbersList)
        CaseNumbers.Add(caseNo);
    // Select the latest case number
    CaseNumberComboBox.SelectedItem = CaseNumbers.FirstOrDefault();
Wolf
by Esri Regular Contributor
@mstranovsky  Your code snippet is not applicable in an ArcGIS Pro Add-in.  There are two patterns in ArcGIS Pro to deploy a ComboBox:
1)   If you are using a Pro Combo box ribbon control you would load the 'Ribbon' Dropdown from a dictionary like this:
internal class TestComboBox : ComboBox
	private bool _isInitialized;
	/// <summary>
	/// Combo Box constructor
	/// </summary>
	public TestComboBox()
		UpdateCombo();
	// create a dictionary with an entry for each US state, the value should be the capital city of that state
	private Dictionary<string, string> _stateCapitals = new Dictionary<string, string>
		{ "Alabama", "Montgomery" },
		{ "Alaska", "Juneau" },
		{ "Arizona", "Phoenix" },
		{ "Arkansas", "Little Rock" },
		{ "California", "Sacramento" },
		{ "Colorado", "Denver" },
		{ "Connecticut", "Hartford" },
		{ "Delaware", "Dover" },
		{ "Florida", "Tallahassee" },
		{ "Georgia", "Atlanta" }
	/// <summary>
	/// Updates the combo box with all the capitals of the US states
	/// </summary>
	private void UpdateCombo()
		if (_isInitialized)
			SelectedItem = ItemCollection.FirstOrDefault();
		if (!_isInitialized)
			// Updates the combo box with all the capital names of the US states
			foreach (var capital in _stateCapitals.Values)
				Add(new ComboBoxItem(capital));
			_isInitialized = true;
		Enabled = true;
	/// <summary>
	/// The on comboBox selection change event.
	/// </summary>
	/// <param name="item">The newly selected combo box item</param>
	protected override void OnSelectionChange(ComboBoxItem item)
		if (item == null) return;
		if (string.IsNullOrEmpty(item.Text)) return;
2. If you are using a combobox on a Dockpane, you should use the MVVM pattern to populate the combobox content.  In this case, please model your code after @SumitMishra_016 's sample snippet.
Wolf
I attached a small sample add-in project that has a Combo dropdown on the ArcGIS Pro ribbon and two dropdowns on a Dockpane.  I am using a dictionary (keys and values) to 'feed' the dropdown content.
