Addin with ArcGIS Pro 3.3
346
05-23-2024 03:06 AM
GrégoireC
I used a plugin in ArcGIS Pro 3.2, and after migrating it to ArcGIS Pro 3.3, my esriaddinx plugin no longer worked. When I examined the source code, I noticed a new error message:
Error message : "Gravité Code Description Projet Fichier Ligne État de la suppression
Erreur CS0508 'ShowCoordinatesTool.HandleMouseDownAsync(MapViewMouseButtonEventArgs)' : le type de retour doit être 'Task' pour correspondre au membre substitué"
in English (translated) : "Severity Code Description Project File Line Deletion Status Error CS0508 'ShowCoordinatesTool.HandleMouseDownAsync(MapViewMouseButtonEventArgs)': return type must be 'Task' to match overridden member."
Did you notice the same issue ?
protected override Task HandleMouseDownAsync(MapViewMouseButtonEventArgs e)
....//Get the instance of the ViewModel
....var vm = OverlayEmbeddableControl as EmbeddedControlViewModel;
....if (vm == null)
........return Task.FromResult(0); //changé le 23/05/2024 pour test
........//return Task.CompletedTask;
....//Get the map coordinates from the click point and set the property on the ViewModel.
....return QueuedTask.Run(() =>
........var mapPoint = ActiveMapView.ClientToMap(e.ClientPoint);
........var coords = GeometryEngine.Instance.Project(mapPoint, SpatialReferences.WGS84) as MapPoint;
........if (coords == null) return;
........var camera = ActiveMapView.Camera;
........var sb = new StringBuilder();
........var zoom = calculateZoom(96,Convert.ToInt32(camera.Scale),(float)coords.X,1);
........zoom = 100;
........vm.Text = sb.ToString();
........string YXZcoordinates = coords.Y.ToString().Replace(",", ".") + "," + coords.X.ToString().Replace(",", ".") + "," + zoom.ToString()+"m";
GrégoireC
I resolved this problem by changing of the .NET version 6 to 8 in the .csporj file of the old vs addin project
<TargetFramework>net6.0-windows</TargetFramework>
to
<TargetFramework>net8.0-windows</TargetFramework>
Wolf
by Esri Regular Contributor
I cannot duplicate your issue.   When you say you migrated your add-in to 3.3 did you upgrade your project to target .NET 8.0?  I have a 3.1 add-in with a MapTool that also is using the HandleMouseDownAsync  overrise and it worked fine under 3.3.   When i migrated the project to ArcGIS Pro 3.3 i get the following when i hover over the HandleMouseDownAsync override:
Also can you check the definition for Task?  It should be defined as follows:
GrégoireC
to
